Cross Section Line Thickness
8 replies to this topic
#1 Kris Marteinsson
Kris Marteinsson
  • 89 posts
  • LocationSalmon Arm, BC
Posted 13 April 2022 - 09:29 AM
I've generated a cross section and saved a drawing of it. The line weights are too thick and the option for print pen - outline pen is greyed out. The texture pen is available to edit. I've looked all over for a system, project or drawing setting for the line thickness. Is there one and if so, where isit?
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 13 April 2022 - 10:06 AM
"Pen Setup" is in all 3 places.
#3 Jim Johnson
Jim Johnson
  • 289 posts
Posted 13 April 2022 - 10:14 AM
I believe that it is set by the layer.  Unchecking Auto Scale Pen Width when it is placed on a Plan Set might give you what you are looking for too.
  • John Jones likes this
#4 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 13 April 2022 - 10:42 AM
Henry,
Yes, pen setup is in all 3 places but which setting is it that controls this? it isn't in cross section details.
Jim,
Unchecking auto scale pen width works. This will do for now while I explore this further.
Thanks to you both for your help.
Posted 13 April 2022 - 12:05 PM
The pens are setup (in all three places) under pen setup. Check CROSS SECTON "X" ITEMS and CROSS SECTION ITEMS in GENERAL ITEMS Not CROSS SECTION DETAILS
#6 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 13 April 2022 - 12:28 PM
Keith,
Okay, found it. Cross Section "X" Items were set to a thick pen width. Cross Section Items were set to the pen width I wanted which didn't work. Not sure what is an "X" Item and a regular Item. Still makes no sense to me that if I save as a drawing, that there are lines for which I cannot edit the pen width. Missing something fundamental here I think.
#7 Wesley Penner
Wesley Penner
  • 59 posts
Posted 13 April 2022 - 02:14 PM
I believe that an "X" item is one that actually crosses your section plane.
#8 Henry Buckner
Henry Buckner
  • 342 posts
Posted 13 April 2022 - 02:18 PM
You can edit any individual line that you like.
#9 Keith Almond
Posted 13 April 2022 - 03:14 PM
Kris,
Quick explanation ... You CANNOT change the pen thickness of ANYTHING on a layer that has a defined pen thickness.
Your options are:
Edit the defined pen thickness of the LAYER in the layer setup OR
Edit the item to be on a layer with a DEFAULT pen thickness, and then edit the pen size independently.
