Anyone why the exterior pot lights will not show unless they are in ceiling 2016
Posted 25 November 2015 - 08:32 PM
Don't know ... I've always created a small ceiling with the same pitch as the roof and raised it up accordingly.
Posted 25 November 2015 - 08:50 PM
put in a 'ceiling" and "adjust" in to the roof overhang.
i presume you want a flat horizontal soffit so
the ceiling will work fine.
than put the pot light in in the electrical mode.
NOTE: you'll have to edit the "offset" of the pot lights
to a positive number > trial and error. have 3d / softview open while doing this part.
NOTE: mine didn't want to cleanup to the ceiling
but maybe it will.
btw, you can also make the pot lights slope to a pitched ceiling
click to enlarge.
v10 to future 2016+
Posted 26 November 2015 - 10:16 AM
If they are in a flat soffit, then yes, they can be offset from the floor as any other item. If they are in a sloping (gable) soffit - which for some unknown reason I automatically assumed - then to slope them with the roof, I don't see any other option than to create a ceiling - unless someone knows different.
Posted 30 November 2015 - 06:59 PM
Sorry I should have said that i know how to put lights in o/h, ceilings, slopes, etc.... what I am having problems with is that there is no light (Fixture) visible in the 3D mode. The glow of the light is there but the fixture isn't no matter what height I adjust too. I did have trouble with all the symbol with the 2016 version but I copied the 2014 symbols into 2016. All seem to work ok except the lights.. I most be missing something .... just not sure what.
Thanks all for your input.
