perpendicular line
7 replies to this topic
#1 Guest_Robert_*
Guest_Robert_*
Posted 03 February 2016 - 10:59 AM
How do you draw a line perpendicular to an existing line that is at an odd angle
  • admin likes this
#2 Yvon Gonthier
Posted 03 February 2016 - 12:19 PM
Don't know if there's an easier way but you can use a box. Unlock the cursor lock first, activate cursor snap, select box and draw the box snapping to your line on that angle. Then, explode the box and erase unwanted lines.
  • admin likes this
#3 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 03 February 2016 - 12:23 PM
I can think of three ways to do this ...
1/  Copy the line on the angle. Rotate the copied line and select the angle to rotate (90 degrees).
2/  Edit the line on the angle. Add 90 degrees to the number. Draw a new line and edit it to the new angle.
3/ Go to Draw > Options > Cursor Options > Pick Cursor Axis.  Click on the line which is on the angle and the cursor will rotate.
You can now draw a line perpendicular to it.
  • admin likes this
Posted 03 February 2016 - 12:36 PM
Press F11 to turn SNAP on, start anywhere you want and draw a line close to perpendicular. You will get a red symbol a small square within an "L" to show perpendicular, and it will then snap to the original line.
#5 Ron Mejeur
Ron Mejeur
  • 66 posts
  • LocationKalalmazoo, Mi
Posted 03 February 2016 - 04:48 PM
If I understand this correctly, I would use the offset command.  Click on the line, use the offset command (type O on my system) and offset distance you want.
Ron Mejeur
#6 Yvon Gonthier
Posted 04 February 2016 - 08:37 AM
This gives you a parallel line, not perpendicular although it's not a bad idea. If you offset your line and then turn snap on, you can draw a line either from the center to center of your 2 lines or the end points and that will give you a perpendicular line (90 degree) from your original line.
#7 Guest_Guest_*
Guest_Guest_*
Posted 04 February 2016 - 09:26 AM
Offset and then rotate 90 degrees.
#8 Philip Frank
  • 560 posts
Posted 04 February 2016 - 10:13 AM
I use Steve's method #3. I use it so much that I even have the "Pick Cursor Axis" assigned to a shortcut key. Really quick to get a perpendicular line this way.
Phil
