Picture upload and scaling
#1 Guest_Jeremy_*
Guest_Jeremy_*
Posted 03 March 2015 - 11:12 AM
I am looking into purchasing softplan. Can you upload a photo and set it to a scale (according to a window/door) and trace over for quick design sketches ?
#2 Guest_Derrik Bauer_*
Posted 03 March 2015 - 11:24 AM
Are you asking if we can upload an image of a plan then trace over it for the floorplan?  The answer is yes, but I don't know of an auto scale function like you described.  I have done this in the past by having a line drawn that is the same length as a feature on the drawing, then adjusted the image to match that length (proportion of the image are maintained).  It's not super fast, but effective.  I have also cropped a plan to the edge of the walls then modified the entire width to reflect the total width needed.
I have used this for plans and sites both.  I use it much more for site plans.
#3 Guest_Jeremy_*
Guest_Jeremy_*
Posted 03 March 2015 - 11:47 AM
Thanks for the reply. I was thinking more like taking an exterior photo, setting it to a scale and doing a quick renovation. i.e. A quick addition, adding trim, changing siding etc. to give a client a look at the potential curb appeal with minimal investment.
#4 Todd Williard
Todd Williard
  • 192 posts
  • LocationPA
Posted 03 March 2015 - 12:14 PM
Sketchup does exactly what you are describing using photo match.
V11-V2024
#5 Guest_Derrik Bauer_*
Posted 03 March 2015 - 12:19 PM
I don't believe SoftPlan has this function built in.  You could do it, but it would take a little more work:  Create a verticle plane, change the texture to a saved image, adjusty the size, then start placing items on it.
#6 admin
admin
    Administrator
  • Administrators
  • 88 posts
Posted 03 March 2015 - 03:35 PM
You should take a look at Edit > Adjust Size.
#7 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 04 March 2015 - 08:14 AM
Yes it is easy to blend a actual photo with a drawing or model
here is an example:
(I think any program will require a little photoshop or similar as well)
-Chris
