Roof on bay window
9 replies to this topic
#1 Bruce Donelson
Bruce Donelson
  • 30 posts
Posted 04 March 2015 - 07:44 PM
Can anyone remind how to put a roof aver a bay window?
Posted 04 March 2015 - 07:47 PM
I assume you mean in a gable ... There are a few ready built symbols in the library.
#3 Bruce Donelson
Bruce Donelson
  • 30 posts
Posted 04 March 2015 - 08:05 PM
Thanks Keith, its a little goofy, but makes a reasonable placeholder. I was thinking of something that looked more like the main roof. But this is better than what I had!
Posted 04 March 2015 - 09:30 PM
You could always draw some beams, hide them, and remove them from "Extract in 3D" and fit the roof to the beams.
#5 Sam Morgan
  • 851 posts
Posted 04 March 2015 - 10:47 PM
roof on bay in draw roof
Posted 05 March 2015 - 09:18 AM
Sam, if the bay is physically constructed of walls, then that works fine. However, with a bay over a flat wall (which I suspect is the case here) or an oriel bay, the window looks flat like the wall on plan and the roof won't pick up the bay.
#7 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 05 March 2015 - 10:37 AM
That is true but it will not make a correct model unless you take the time to draw a wall which you can generate a roof with and then you have a good model which will generate correct elevations and roof plan.
-Chris
Posted 05 March 2015 - 11:39 AM
Doesn't that depend on whether it's a walk in bay or just a bay window?
#9 Keith Owens
Keith Owens
  • 96 posts
  • LocationConnecticut
Posted 05 March 2015 - 12:01 PM
If it's just a bay window (not a walk in bay) with a shingled or maybe standing seam roof, then typical what I would do is build a 2x6 box around the top of the window with a plate on top, then set the bay roof rafters on top of that. If you draw the model like that it will provide an accurate model, and an accurate takeoff. I typically use Andersen windows, and their bay style has a cable support system that would be hidden within the roof structure. This way the top can be insulated properly as well - if your building in a cold climate zone.
#10 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 05 March 2015 - 12:42 PM
Yea I do the same -either a short wall or plate
And landings make good bottoms and ceilings
-Chris
