Is there a "paint" for this texture? This would be for elevation drawings.
Thanks for your help.
Posted 21 August 2017 - 11:03 AM
Not a standard one, however, there's one I made that's close, attached to this post http://softplan.com/...tterns/?p=10736
Posted 21 August 2017 - 01:33 PM
The one you showed had a straight section between the arcs, where mine was just arcs. Having said that, its a piece of cake to edit, if you want the straights.
Posted 22 August 2017 - 06:27 AM
Just in case anyone need the longer extended scalloped edge ...
Posted 22 August 2017 - 08:21 AM
You don't save the zip file to Softplan. Save it to somewhere convenient in your documents, and then extract it - there's only one file in it (a standard Softplan .SPY file) - and then either move or copy that file into the relevant location in your Softplan paints folder.
