i no this was on here but i can not seam to find it it has bin a long time since i needed but now i could use a little help
Thank You Ron
Posted 22 August 2017 - 08:22 AM
Go into the drawing library, find the specific window and add to it or edit it directly in the drawing library to suit.
Posted 24 August 2017 - 07:56 AM
you need to create a new window in the system or drawing symbols. Another way that i do it is I will just add a another window to the plan (a little off but still on the same wall) and then use either my 3D model or view to move it in to place. As it gets closer it will automatically mull itself together. That method is a good quick fix if it is not a window you are planning to use again.
Posted 24 August 2017 - 08:04 AM
What you're looking at is good only to add a rectangular or square transom. What Keith is talking abour is you have to edit the window and save under another name. Then you Edit Symbol>Add in Configure Opening>Select the window you want to add on top and select Location to Add. Adjust size of your transom as required.
