Posted 07 September 2017 - 10:45 AM
I have been having an issue with the snaps wanting to pick on the outer material that is turned off and not on the bearing material. Has anyone been having this issue as well?
Posted 07 September 2017 - 11:31 AM
Try setting the shading on the invisible material to none.
Posted 07 September 2017 - 12:48 PM
I have found the issue. The texture visibility was on. As soon a I turned it off the problem went away. Thank you for your suggestion.
