Transom Windows
#1 Guest_Dan Schellenberg_*
Posted 15 November 2017 - 02:57 PM
We recently upgraded to 2018 from 2012.    I want to add a transom window or any other window above a window at varying spacing between the windows.   On a brick wall, the brick between the windows disappears and I have to add the brick back in with cubes, very awkward.   Why is this doing this and what can I do to make this stop.
Thanks so much
Posted 15 November 2017 - 03:51 PM
It's because Softplan is trying to create a unit opening for trim purposes.
Go to the header tab in the EDIT menu, and check "EXCLUDE FROM UNIT OPENINGS". That will put the exterior finish back.
#3 Guest_Guest_*
Guest_Guest_*
Posted 15 November 2017 - 04:12 PM
Perfect!  Thanks so much
