I am unable to print a rendered image to fit any paper size without having a border on the sheet. Is there a way to do this? Not coming up with much.
Thx,
C
Posted 21 December 2017 - 09:53 AM
Hi Chris. When I render for print, I first decide how many dots per inch I want to print at. I don't usually print at less than 150 dpi. You have to multiply your sheet size by the dpi to determine the resolution that you will render at.
For example, if you are printing on 11x17 paper @ 150 dpi your final rendered image size should be 2550 x 1650 (17x150, 11x150) . The higher the dpi you want to print at the higher the resolution of your image.
When you render this way you will be able to fill the page with the print (no border) and will not have to scale anything and risk throwing off the way the image looks. I hope this helps!
