Version 2016.
I notice that the UNDO icon bottom does not work same way as it did on previous versions.
Why?
Posted 30 March 2015 - 09:40 PM
Version 2016.
Why?
John LaBorda
President
Mediterranean Homes Inc
3923 Chiquita Blvd South
Cape Coral, Florida 33914
E-Mail: Mediterranean.Homes@Hotmail.com
Phone: 239-898-9868
Posted 01 April 2015 - 08:05 AM
Funny, I was going to ask that ... Not sure how UNDO could possibly work differently!
Posted 01 April 2015 - 09:19 AM
check your system options for "undo" and see if it is set the same as compared to 2014
Tommy Davis
HomeOptionsDesign@gmail.com
Posted 01 April 2015 - 12:40 PM
With the way Softplan zooms, is there any point at all in a undo on the zoom ... any point? ...
Posted 01 April 2015 - 12:42 PM
Ok, try this.
Select a wall, in my case an interior frame wall...draw a box (any size)...select item extension (to draw both ends of wall extension) you know what it does't work...only a single extension.
Now try with an exterior wall...in my case drawing with ICF wall and do same as above...item extension works!
Now dimension it and click on it and reduce it to any size...ok right now do UNDO and you will find out what I mean that it does not work like other version of softplan.
John LaBorda
President
Phone: 239-898-9868
Posted 01 April 2015 - 01:42 PM
Well, I suppose it's a reason - typically I know what I need to undo.
Is it possible to turn it off (like the "enable multiple undo") in the system options. If not, can it be suggested that it is able to be turned off.
Personally, I don't really see much point to it, and can see it getting annoying quickly. Although maybe I should try it first!
