Has anyone had anything like this happen? No matter what I do with this roof, the shingles on the front hip do not appear....at the end of my rope....
Posted 30 January 2018 - 02:25 PM
Posted 30 January 2018 - 02:55 PM
I've been seeing it more recently too ...
Tech Support's response:
I will forward this issue onto our development team for further review. It seems to be related to Multiple Floor Roof.
I would try adjusting the lollipops or delete and redo the roof and see if either of those solutions work for now, but it does appear to be a known issue.
Posted 30 January 2018 - 07:14 PM
You can also try editing it to a gable, and then editing it back to a hip.
Posted 31 January 2018 - 08:21 AM
Open a Ticket with Technical Support.
Posted 31 January 2018 - 08:56 AM
Anyone had this problem? I have to edit the Roof Edge to fix this every time I open the Project. The only way to fix this is to not use multi-roof and draw the main roof on the first floor and draw the second floor roof on the 2nd floor. The siding not lining up is an issue. I save the elevation as a line drawing and add paint to fix it.
Rick
Posted 31 January 2018 - 07:53 PM
There is an "adjust to soffit" right next to the "cover floor" function that does just that. Although to be fair it sometimes doesn't do it correctly. I think it's been tweaked recently so that it does a much better job than it used too.
