noel,
what version are you using.
i understand you've already drawn the profile of the crown and saved that.
now you can't see it in the crown molding library.
try instructions below and follow exactly.
in v2016.
btw, i tried to duplicate your problem and added a NEW profile to the crown molding library
which i had done many time in previous versions. had the same issue your having.
i could always get it to show up after doing a few things, it's been a few years.
when creating new custom profiles, you won't usually have this issue.
if you call tech, ask them about it and maybe do a write up on the procedure
so we can all copy it for future use. ask them why does it work when creating
some custom profiles and not with all.
go to HELP in softplan (top of page)
use the "search" tab and type in
"adding profiles to library"
see if that helps.
if you still can't see it where you put it, let us know.
sometimes you have to take an extra step or two to
make sure it gets in the library, i never could understand
why that happens on occasion with certain profiles & libraries.
most of the time it ends up where you put it and you can see it..
other times you have to go thru a few extra steps.
i've had to go thru those steps a few times but haven't
had to do it in a long time and forget the exact procedure
when they don't behave properly.
if you can't get the answer your looking for,
you might want to send a ticket to softplan tech or call them up.
btw, when i mention sending a ticket, that's if you have the (+) version.
otherwise, call them.
SoftPlan Technical Support
Telephone: 519-886-9750
PS,
could you share the procedure with us when you get it ?
btw, most of the time when you draw a specific profile, it's
be in the library where it's supposed to be. i have no
idea why with some profiles & libraries, it doesn't work that way.
could you ask tech about this ?
