" Rafters are not a problem....but I just can't figure out how to get trusses to draw like a stick roof when it comes to the layout of trusses on the roof plan"
Sometimes, when drawing trusses you have to keep in mind that they don't always follow the way of stick framing. Ridge beams can be replaced with girder trussses that span a lot more distance. Mono trusses are not built as framed jacks. But typically, what i do is to create a truss drawing that works, but when it goes to the manufacurer, & they have run it past thier software, they can change the configuration. So, i feel as long as i present a solution they can do what they wanyt with it as long as they have taken in all the bearing points.
