Has anyone produced a 3d walk thru yet? Where can I see some samples?
Posted 02 May 2015 - 08:24 PM
Is there even a RENDERING GALLERY anymore? If so, can someone point me at it ...
I'd like that think that we could post created walkthroughs to a Gallery within this forum. That would be awesome.
Posted 04 May 2015 - 07:27 AM
Dean,
Here is one that I did using the keyboard only.
https://www.youtube.com/watch?v=0aXncRvtqkQ&feature=youtu.be
I am going to be purchasing a 3D Connexion mouse soon, and anticipate much smoother transitions in the animations.
Tommy
Tommy Davis
HomeOptionsDesign@gmail.com
Posted 04 May 2015 - 07:38 AM
Posted 29 March 2016 - 07:40 AM
I've been working on the animation and the process that Softplan uses. The major point when you start out is that when you're creating your animation, you're in reality creating the path to be used when you replay the animation. The path that will be created is NOT necessarily the complete path you go thru when creating your animation. It is more about how you set the frames than about the actual route. SoftPlan will take the shortest path between frames. Therefore you should create a new frame every time there is a change of direction or change of angle, in short, any deviation from a straight path otherwise you'll go thru walls and floors.
Since you're recording only the path, any changes to your plans or selection in building options will appear when regenerating the animation.
A couple of problems I have right now are;
1- If I want to activate the reflections (RE) in textured mode, the animation is not very smooth. It jumps between different frames at different intervals.
2- Not sure how you actually save the actual animation you just went thru (the movie, not the path). This is probably why I'm not seeing the option to publish to You Tube?
Posted 29 March 2016 - 09:28 AM
I'll help with #2:
Saving the animations is done through the export to file function:
From there you can directly publish to Youtube, but I prefer to use the free (I think its free...) program "Microsoft Movie Maker" to create the final product. It allows me to insert still images including my Logo along with combining multiple walk-thrus and exterior spinners to create one longer more presentable movie.
On this same note, I have found that higher quality animations require so much RAM that I have to break them up into smaller 15-30 second sections then combine them in the movie maker program. It sounds complicated, but it actually works out pretty well and is easy to figure out.
Posted 29 March 2016 - 01:41 PM
Posted 30 March 2016 - 02:22 PM
Here is finally my first completed animation. Interior animation didn't really start where I wanted and kind of goes backwards at the beginning but more to learn. Test set-up put together with Movie Maker as suggested. Added music but not sure it plays in You Tube. Not sure if this will play since uploaded as private instead of public?
https://www.youtube....eature=youtu.be
Posted 04 May 2016 - 12:24 PM
Softplan has to improve the time it take to record the walk thru (wmv) to make it reasonable to work with. Just spent 2 hours recording a ground floor walk thru and at the end got an error message and only +/-20% actually recorded. Another huge problem is that when recording the walkthrough (wmv), Softplan can't be used??????
Posted 05 May 2016 - 08:59 AM
If your not aleady doing so try using "keyframes" to author the path. We find most users complaints come from trying to record the mouse. Setting keyframes is fast, easy and flexible.
I use the arrows to move and click on key frames at every change in direction as shown in attached drawing. Is this what you mean? My problem is generating and saving a wmv file which is what is so long and freezes the use of Softplan.
Posted 05 May 2016 - 11:50 AM
Posted 05 May 2016 - 01:50 PM
Here is our YouTube channel with the animations I have done so far.
https://www.youtube....nSgSlQUYoUom16g
I wish you could do an animation in rendered mode. The textured take long enough.
Posted 05 May 2016 - 02:05 PM
Was this done in rendered mode? I see the reflections in the mirrors.
Posted 05 May 2016 - 02:46 PM
No, it was done in textured mode. Find some items that I don't like in rendered and to heavy. But, I have the "Relection" turned on. When in 3D, in the middle of the tool bar, you have an icon "Re". If you click on it, it will turn the reflections on or off. Still makes the process to convert to a movie file pretty long but I don't think as bad as rendered mode.Was this done in rendered mode? I see the reflections in the mirrors.
