Can't get adjust to work.
#1 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 22 May 2019 - 06:15 PM
I have an survey image (jpg) that I'm try ing to get to the proper scale.
I pick the Edit tab, then adjust size, then window the drawing with generous proportions.  That brings up the "adjust size" dialog box.  I click on distance then enter the distance.
Next I'm supposed to pick the to endpoints of my distance but when I click on the first endpoint my cursor turnes into a window.  It won't let me click on two points.
If I click on scale and enter 2, that works.  I have rebooted and restarted SP.
What the heck am I doing wrong here.
My survey is totally useless unless I can scale it.  It doesn't have enough dimensions to completely reproduce it without tracing some of it.
Posted 22 May 2019 - 07:11 PM
You can't pick endpoints of a RASTER image. You will have to do a lot of trial and error adjustment on a JPG. The adjust size - distance only work on VECTORS.
What I would do, is draw a line over a known distance on the survey, and then edit it to find it's length (or dimension it). If it's 25' and it should be 100' then use scale = 4 (100/25). Obviously it's never going to be that straightforward, but that principle will get you what you the multiplier that you need.
#3 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 22 May 2019 - 07:50 PM
Thanks, You are correct sir.  I forgot you can't pick on an image inside it.  I forgot to draw guideline to the outside to use.
Sure wish I could bring in some commands from autocad.
#4 Don Gibbons
Don Gibbons
  • 375 posts
Posted 23 May 2019 - 03:39 AM
Yes you can pick two points in an image. I use Adjust Size and Distance on images all the time. You can't snap to them.
  • John Jones likes this
#5 Jim Johnson
Jim Johnson
  • 289 posts
Posted 23 May 2019 - 04:09 AM
You have to select the image first.  Then click adjust size>distance, enter your known distance, and then click each end of the know distance on the image.  Key is to first select the image.
#6 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 23 May 2019 - 05:14 AM
Well what do you know, that works exactly like  you said.  Thank you very much.  Now if I can just remember how that works.
Posted 23 May 2019 - 10:23 AM
Learnt something new ... Again. Thank you.
