How to get subfloor to show in elevations
#1 Joshua Brown
Joshua Brown
  • 14 posts
Posted 28 May 2015 - 09:12 PM
Hello,
I am currently trying to model a proposed drainage system. I am trying to make a drawing to show dimensions, however the subfloor doesn't seem to show in the elevation views. Is there a way to make them show? Thank you.
#2 Yvon Gonthier
Posted 29 May 2015 - 06:16 AM
Not sure I understand your question? Your talking about drainage and subfloor? What kind of elevation are you trying to generate. On standard plans, you have your exterior finishes that hide the subfloor.
Posted 29 May 2015 - 06:20 AM
I must admit, I too am vague about why you want to show subfloor on an elevation, normally you get subfloor on a section? Can you explain what you are doing and what you need in a little more detail, please. We can then try and figure out the best way to help you.
#4 Joshua Brown
Joshua Brown
  • 14 posts
Posted 29 May 2015 - 10:42 AM
Sorrry about the misunderstanding. Basically I am trying to show a drainage system for a foundation. Just a 2D image of the foundation wall, slab, pipe system (which I imported from SoftPlan), and the floor. I asked a question a few days ago about how to turn my elevation view into a drawing which helped me out significantly. However, when I have the elevation view it does not show the floor. This model is less about accuracy since I will be doing the dimensions manually as an example and more about showing what is the proposed fix. Is there any way I can show the subfloor or model a floor on top of the slab.
#5 Joshua Brown
Joshua Brown
  • 14 posts
Posted 29 May 2015 - 10:48 AM
Sorry about the vagueness that was not my intention. It might mostly be to my inexperience but basically I am looking to model a 2D image of a foundation drainage system. I want to create a 2D image of it so I can show the foundation, footing, slab, pipe system (which I made a imported from SketchUp), and the floor. However, i cant get the floor to show in the elevations. Like I said it might mostly be due to my inexperience with SoftPlan. Is it possible to make a section cut and use that as a drawing to dimension the model?
#6 Yvon Gonthier
Posted 29 May 2015 - 10:51 AM
Maybe having a section instead would work better and show all your floor and wall components?
