I have a front porch slab that I want to run to foundation overlay, but it snaps to the overhead beam supporting the roof over the porch. If I turn off clean up, it snaps to the outside of the beam, but will not let me drag it a few inches past that point. This should not be this difficult, should it? Why would the slab snap to ANYTHING (let alone a beam 9' above it) once clean up is unchecked? Any ideas?
Slab snaps to beams?
Started by
Dave Pazyniak
, Jun 10 2019 11:18 AM
Posted 10 June 2019 - 12:13 PM
Dave,
I am not sure why it is doing that and I agree it should not. If it is not an enclosed porch, ie. screened in or other enclosure I usually draw it as a patio in site mode.
Maybe this will help. as you can extend the patio past the building line with no trouble.
Posted 10 June 2019 - 04:49 PM
It has always snapped to the beam. Drives me nuts. However, I am able to adjust to the correct location as needed.
Make sure your slab is “level 2”
A suggestion was put in years ago to correct the slab to beam issue, but alas, it has not been rectified.
- Tom Rogers likes this
