Does this drive anyone else nuts trying to get baseboard to wrap around the end of walls? We run into this in a few places on every project. The corners of the baseboard miter but won't wrap the corner. We can't get the reference circle to fill solid at the end. Any tips?
Posted 24 April 2020 - 11:23 AM
Are you using the Room Mode or Interior Mode? I don't think the option adding baseboard under Room will work unless the hall and living room are drawn as one room. If you use Interior and add baseboard there by tracing all the walls you want baseboard on, I think it will work. Don't know if this is the issue but checking.
Posted 24 April 2020 - 12:17 PM
Then again, door and window casing usually partially covers a door or window jamb on the inside. And, we have no control over this either. I tend to not show or focus the details of SP's short-comings in my 3D views or 2D drawings and expect most builders know the reality of how things are built vs the limitations of the program. If not, I draw details that are correct to relate the intent. I don't show details of framing often for that reason either. While you can fake it to a degree, it isn't how it is built, so I try not to show it in close up detail. And, if I need to I drawing other ways.
Posted 24 April 2020 - 01:36 PM
Its a bummer though. I draw 80% custom homes and pretty much all of them meet with me to do live walk-throughs. So i like it to be as close to "reality" as possible. Got to love solids!!!
- Warren Ducote and Mark Petri like this
Posted 27 April 2020 - 12:41 PM
See the attached image from SoftPlan version 2020. I added rooms and used standard arch openings as well as an exposed wall end. The baseboard wraps when there is no trim on the opening.
If you're seeing different results, please let support know and be sure to include your version and a drawing.
- John Jones, Rick Kingsbury and Allen McDonnell like this
Posted 27 April 2020 - 03:10 PM
But what if the arch openings have trim? Needs to be corrected.
#11
Posted 28 April 2020 - 03:15 PM
Sorry for my tardiness in replying everyone. Just to clarify, that is not an opening; instead, it is a wall end at the head of some stairs.
Most times it will wrap wall ends but there is always a few on every project that it will not. Drives me nuts as you can waste SO much time messing with it. I've used "snap", no snap and everything I can think of.
Thanks everyone.
Posted 28 April 2020 - 04:35 PM
Good to know Jay. I think the "lollipops" try too well to clean up and snap to other things in some situations. I notice they have a tough time on ends of walls occasionally. I will try to remember to do more experiments when I am in a drawing I can mess around with.
Also tagged with one or more of these keywords: baseboard, wall end
Horizontal outletsStarted by Jeff Vannette , 04 Sep 2021 Electrical, Outlets and 3 more... |
Butt end of wallStarted by Jerry Gagne , 05 May 2021 wall end |
