Most of my builder clients use pre-hung interior doors with the 2 1/4" colonial casing. This casing has a 1/4" offset/reveal of the door frame. I can find the "Colonial" interior casing under profiles in system library. When I click on "Edit Symbol" it pulls up the configure profile window but doesn't give me the option to customize the trim. The default of this trim is 2.750" wide. How can I customize or add a new trim profile so I can show the 2.1/4" trim molding on my doors and windows?
Another issue I've discovered is the inside part of trim starts at the outer most edge of the window or door frame when it should show only a 1/4" reveal or overlap of the window or door frame. Any chance this can be customized?
