I'm designing a house using ICFs for the basement and main floor exterior walls. After adding the floor system, the main floor walls keep offsetting up the 3/4" for the subfloor, as if the main floor walls would rest on the subfloor as in traditional framing. Is there a way to turn the automatic offset off? I've added a ledger for the bearing end of the floor truss and raised the beams so the tops of the trusses, ledger, and beams are in the same plane.
