Hi all,
I'm looking for trips/tricks to clean up these soffits. How I put it together as different roof planes is very chopped up/messy - so I'm not surprised it turned out this way. Criticism welcome!
Thank you!
Derk
Posted 09 November 2020 - 05:54 PM
Sometimes it is best to turn off soffits and either create another roof, set it with a shorter heel height and cut holes where you don't want to see the roof. Or, draw a ceiling and do the same, adjusting the offsets to get what you want. Softplan does not model soffits correctly on very simple roofs. Complicated roofs are super problematic as you see. Another option which sometimes can work is to draw a profile while in 3D view and select the correct surface to reference. I find that to have mixed results as well though. Often I resort to drawing a ceiling and un-checking clean up, then adjusting to just inside of the fascia.
Posted 10 November 2020 - 09:37 AM
I hadn't done profiles in 3D before! Thanks for the tip, Mark. Is there a way to clip the corner? profile.JPG 52.87KB 0 downloads
Posted 10 November 2020 - 01:11 PM
The best thing is to continue the profile down the next wall or all the way along until it can end at a good transition point. Unfortunately it will only reference the initial plane to start and itself. From what I understand the profile drawn is not easily modified once placed.
Raise Roof - Window Pediment Clearance, Heel Height, Knee WallStarted by Steve Gray , 08 Feb 2024 Roof, Knee Wall, Raise Roof and 1 more... |
Roof SettingsStarted by Mark Petri , 11 Dec 2023 Roof, Settings, Project Settings and 2 more... |
Drawing Roof PlanStarted by Bruce Schlittler , 10 Sep 2023 Visibilities, Roof |
Guest Area →
Guest Questions →
Auto Adjust IssuesStarted by Shania Clay , 23 Aug 2023 Cleanup, Basement, Auto Adjust and 2 more... |
How to Model Roof CablesStarted by Verlin Klassen , 15 Mar 2023 Cable, cables., roof cable and 2 more... |
