How to Model Roof Cables
Cable cables. roof cable roof cables roof
7 replies to this topic
#1 Verlin Klassen
Verlin Klassen
  • 276 posts
Posted 15 March 2023 - 01:12 PM
I have a client who wants a couple small roofs held up with cables as shown in the attached. Can anyone give me an idea how to model the cables in SoftPlan?
Verlin Klassen
Westman Drafting
#2 Verlin Klassen
Verlin Klassen
  • 276 posts
Posted 15 March 2023 - 01:19 PM
I think I figured out a way to do it. Beams can be sloped, so I will use a round log beam, size it to suit and put the right texture on it.
Verlin Klassen
Westman Drafting
#3 Fred Dickson
Fred Dickson
  • 279 posts
Posted 15 March 2023 - 01:29 PM
This cable from 3D warehouse might work as a starting point.... You can make roof a bunch of ways....
#4 Matthew Dunson
Matthew Dunson
  • 244 posts
Posted 15 March 2023 - 02:44 PM
I would recommend using a model from the 3D warehouse as well since you can get the smaller details on the cable connections opposed to a beam inside SoftPlan (I try to go for as much detail as possible for rendering), but again there are multiple ways to achieve the same goal and I think SoftPlan has an easy process of importing Sketchup Models. You can also use the Brace function inside SoftPlan and scale it down to cable size and use solids to mimic the connection plates.
#5 Mark Petri
  • 1,874 posts
Posted 16 March 2023 - 06:40 PM
I use beams set to the right diameter with some solid cubes, polygons, or whatever makes it look decent for initial concepts. If we are going to final I will model something in SketchUp or do some details that show it better.
#6 Richard Rubinski
  • 698 posts
Posted 17 March 2023 - 08:17 AM
I found the Canopy and Cables as a unit on 3D warehouse a couple of years ago, maybe it will work for you. The zip file has 2 different sizes.
Rick
#7 Verlin Klassen
Verlin Klassen
  • 276 posts
Posted 18 March 2023 - 07:48 AM
Thank you for your replies. I ended up using the beam idea. That way I had infinite control for length, and height, and location.
Verlin Klassen
Westman Drafting
#8 Joseph Smith
  • 853 posts
Posted 23 March 2023 - 07:48 AM
I used log beams and cubes in this example.  The symbol is fine but if you need control over cable angle the symbol isn't the solution.
  • Matthew Dunson likes this
Also tagged with one or more of these keywords: Cable, cables., roof cable, roof cables, roof
