Single Extensions
14 replies to this topic
#1 Bill Wimberley
Bill Wimberley
  • 622 posts
  • LocationSan Angelo, TX
Posted 20 July 2021 - 12:36 PM
What do you think about how version 2022 single extensions work?
"Extension Lines placed with the Single Extension command will pull from the closest extendable location rather than use the System/Project/Drawing setting.
This applies to extendable objects including Openings, Shapes, Solids and Posts.
This makes it easy to pull an extension from the center of a window and the edge of a garage door without having to change and change back the extension location configuration."
Personally, I hate it. There has not been a single case where I have benefited from this change and I am constantly having to erase and redo extensions that did not work as expected. Multiple times every day I have to fight the way that single extensions now work. Perhaps some would find it beneficial when drawing extensions from openings. But pulling extensions from everything else does absolutely nothing but cause problems over and over all day long for me. How do you feel about this change? Does it actually benefit anyone?
  • Warren Ducote likes this
#2 Joseph Smith
  • 853 posts
Posted 20 July 2021 - 12:44 PM
I dislike trying to get a dimensions of a 3-1/2"x3-1/2" square...newel posts or anything else small and rectangular.....the extension never grabs and goes the proper direction...generally takes me 3 attempts each time.. very frustrating and slows down my process.
only once case i love the extension feature would be cross openings at my foundation I use r.o. vs centers.
pretty sure your same issue but less eloquent.   :)
#3 Sam Morgan
  • 938 posts
Posted 20 July 2021 - 01:39 PM
I guess there's one more reinforcement on why I haven't upgraded yet.
  • Gary Wicklund likes this
#4 Bill Wimberley
Bill Wimberley
  • 622 posts
Posted 20 July 2021 - 02:32 PM
Hey Sam. I don't know that I would recommend holding off on upgrading. Version 2022 has a ton of improvements that are spectacular. My only problem is the changes they made regarding single extensions and some problems with schedules. Other than that version 2022 is the best version ever.
#5 Mark Petri
  • 1,874 posts
Posted 20 July 2021 - 03:08 PM
I finally started a remodel job in 2022 as my first full project with the upgrade. A few kinks getting worked out. Certainly some features I have to get used to. I agree with Joe - it does not work well on smaller objects. Gotta zoom way in to be sure it is correct.
I don't find it bad with remodel projects where I ultimately prefer to dimension to center of openings, but need the rough or frame dimensions for layout of as-built drawings. I prefer center line dimensions for a cleaner look and a little less liability on the final sizing (contractors and owners always seem to make changes before final windows are ordered).
Posted 20 July 2021 - 07:40 PM
Having not upgraded yet - due to workload and three of us having to upgrade together - I find it hard to comment, but the concept seemed good to me. My problem has always been the constant changing of centre to edge dimensioning, so the idea was good ... ish.
My preference,  that I had suggested on more than one occassion, was TWO separate extension options on the toolbar. Where we have ONE single extension at the moment, I suggested that we have one EDGE EXTENSION icon and one CENTRE EXTENSION icon, so that you could PRESELECT whichever you wanted very quickly.
Obviously Softplan thought this way was better ... from what I hear, maybe not so!
  • Chris Proost likes this
#7 Bill Wimberley
Bill Wimberley
  • 622 posts
Posted 20 July 2021 - 09:22 PM
Keith, what I had suggested is that they leave single extensions unchanged from previous versions but if you hold the shift key down while dragging the extension then you could select the location where you wanted the extension to pull from. That way you could choose how you wanted single extension to behave. Normally it would behave as it always has. But if you hold the shift key you could select the edge or center of an opening or shape. Having single extension just completely ignore the extension settings really messes everything up for me and causes tons of extra work.
  • Jim Johnson, David Zawadzki and Denis Reis like this
#8 Denis Reis
Denis Reis
  • 93 posts
Posted 21 July 2021 - 10:02 AM
I love this idea! Hope they implement it into the next patch....I'm not 100% convinced on the new extension feature - always takes a few tries to get the right extension
#9 Joseph Smith
  • 853 posts
Posted 21 July 2021 - 10:36 AM
'Align to edge' command requires me to hit the escape key to get out of the command
Quickly editing interior dimensions requires me to hit the escape key to get out of the command
These are my two most hated time wasting features of the 2022 release.
  • Jim Johnson likes this
#10 Henry Buckner
Henry Buckner
  • 342 posts
Posted 21 July 2021 - 10:43 AM
<'Align to edge' command requires me to hit the escape key to get out of the command>
Agree, it's a nuisance. But 2020 was the same way for me.
#11 Bill Wimberley
Bill Wimberley
  • 622 posts
Posted 21 July 2021 - 11:24 AM
Joseph, I have the Space Bar defined as the Keyboard Shortcut for Edit Item. So I can exit any command by simply tapping the space bar. A lot easier than having to reach up and find the Esc key.
#12 Joseph Smith
  • 853 posts
Posted 21 July 2021 - 12:18 PM
years ago i taught myself to use the mouse on the left so i could use 9 key pad right handed efficiently when typing dims and number data....at this point slapping the esc is pretty quick.  Thanks Bill.
#13 Joseph Smith
  • 853 posts
Posted 22 July 2021 - 12:32 PM
Prime example of Bills comment. the below took 4 tries to create this simple extension....it kept trying to go the horizontal direction.
#14 Harald Schwegel
Harald Schwegel
  • 81 posts
Posted 22 July 2021 - 01:35 PM
The direction of the extension line depends on the location (direction) of the cursor when the end point of the extension line is chosen. It is all proximity based, meaning that in the example below releasing the cursor in the yellow area will result in a vertical extension while releasing in the cyan area will result in a horizontal cursor.
The further zoomed out you are from the object you are pulling the extension from the more important it becomes to move the cursor accurately, that is into the yellow zone and not in the cyan..
Hope this helps.
  • Joseph Smith and John Jones like this
#15 Joseph Smith
  • 853 posts
Posted 22 July 2021 - 02:41 PM
Thanks Harald!
