When I edit symbol, the edit does not show up in the project. Why?
#1 Nicholas Colantuono
Nicholas Colantuono
  • 81 posts
Posted 28 July 2021 - 02:21 PM
When I edit a symbol, the edit does not show up the project, for exaple, I change a 2' window to a 2'3" window.
When I go back in to recheck the edit it says 2'-3" in the system option but does not update in  the plans.
Why?
#2 Mike Adams
Mike Adams
  • 247 posts
Posted 28 July 2021 - 02:31 PM
Did you save it?
#3 Richard Rubinski
  • 611 posts
Posted 28 July 2021 - 02:51 PM
Go to Drawing options Library find the window and click on "Reset Symbol". Then you may have to edit that window in the drawing and uncheck product code and recheck it.
  • Karl Maas likes this
Posted 28 July 2021 - 03:54 PM
As Richard suggests. UNCHECK and RECHECK product code. Openings typically don't regenerate correctly until you do.
Bear in mind ... Adjustments made at system level ONLY affect projects opened after the adjustments are made. Drawings follow PROJECT OPTIONS, not SYSTEM OPTIONS, So you have do do resets to project for drawings and reset to system for project to initiate changes made at system level.
