Layers - "Group" Column
12 replies to this topic
#1 Richard Taylor
Richard Taylor
  • 179 posts
Posted 09 August 2021 - 08:49 AM
Not sure what the "group" column on the Layers panel is for, is anyone using it?
#2 Joseph Smith
  • 824 posts
Posted 09 August 2021 - 09:02 AM
Great question!!
I'd wondered that also, its annoying, too wide and taking up valuable space on my screen now that we can attach the layers dialog box.  when i make the column narrower it doesn't stay for long before defaulting back to the way it originally started.
Either get rid of that column or give us the ability to make it tiny or move it  to the last right column.
#3 Richard Taylor
Richard Taylor
  • 179 posts
Posted 09 August 2021 - 09:04 AM
:) That's exactly why I asked...someone's got to be using for something...otherwise, I'd prefer to have it go away.
  • Joseph Smith likes this
#4 Dennis Asher
Dennis Asher
  • 206 posts
Posted 09 August 2021 - 10:28 AM
A Group Layer will contain more than 1 layer in that group.  By clicking the box in the 'visible' column you can turn visibility on or off of every layer in that group.
  • John Coyle and Stephan Page like this
#5 Chris Proost
Chris Proost
  • 139 posts
  • LocationRichmond, VA
Posted 09 August 2021 - 11:55 AM
I use it to make a "client set" of plans that do not include certain information I do not want them to see. I have created a Marketing group where I can just toggle that group of layers on or off with just one click.
  • David Zawadzki and John Coyle like this
#6 Richard Taylor
Richard Taylor
  • 179 posts
Posted 09 August 2021 - 12:06 PM
Makes sense!
#7 Richard Taylor
Richard Taylor
  • 179 posts
Posted 09 August 2021 - 12:09 PM
I noticed you can rearrange all of the columns except the "group" one. If that one were able to be moved right it would help Joseph and me.
#8 Richard Rubinski
  • 611 posts
Posted 09 August 2021 - 01:23 PM
I would be nice if you could right click on the row and put a check mark for the columns you want displayed, like you can in Quickbooks, Outlook and many other programs.
#9 Keith Almond
Posted 09 August 2021 - 02:59 PM
If you use groups, then you'd realise why it needs to be where it is - Moving it right isn't an option.
It allows you to group sub layers and turn them ALL on or off together.
Attached File  2021.08.09_14h54m23s_001_.png   28.79KB   2 downloads
#10 Joseph Smith
  • 824 posts
Posted 10 August 2021 - 01:46 PM
I'm confused as to why this column can not be moved, some folks use groups and some do not. These cells should have a movable slider like the rest, layer name is more important then groups which I do not use.
  • Richard Taylor likes this
#11 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 16 August 2021 - 08:02 AM
Joseph - think of it as the grouping that is done in spreadsheets.  If you have ever done much work in spreadsheets, you can group a bunch of rows into one group and then either show the group or not.  Another similar comparison is in Windows Explorer.  It's like a folder that has a lot of files and/or other folders inside of it that you can choose to open and show or not.  This is the same thing for groups in layers.  You may want to set various items to different layers in your drawing so that you can turn them on or off at will.  Several of these may fall within a common category and that would be your group name.  If you look at Keith's example above, he has a number of layers that are all part of the "Proposed" group name.  These layers help to identify the items that will be shown, or not shown, in this group.
#12 Joseph Smith
  • 824 posts
Posted 16 August 2021 - 09:12 AM
Thanks Tim,  i'll try to adjust my process to make use of groups....i have a few ideas that might work for me.
#13 Richard Taylor
Richard Taylor
  • 179 posts
Posted 16 August 2021 - 09:14 AM
I don't think these two things are incompatible - using groups, AND being able to move the groups column to another spot further down the line.
