How to Shade a door Section?
#1 David Edlin
David Edlin
  • 45 posts
Posted 23 August 2021 - 03:18 PM
Hi all
Attached is a door section with Victorian moulding, what is the best way to make the section shaded?
Paint solid was used however it does not go to the edges as intended and likewise any hatching looks similar.
Any suggestions please?
Regards
David Edlin
#2 Joseph Smith
  • 853 posts
Posted 23 August 2021 - 03:32 PM
Closed polygon seems to do the trick, sadly you'll have to trace your profile with a polygon, may take awhile.
trace with polygon then edit the polygon and make it solid
you're lucky, the previous release wouldn't do this with a polygon
#3 Jim Johnson
Jim Johnson
  • 289 posts
Posted 24 August 2021 - 10:16 AM
You can select the door section and Edit>Form Polygon to save some time.
  • 5,298 posts
Posted 24 August 2021 - 11:27 AM
Yes, but painting small sections is almost impossible to get clean. The paint algorithm doesn't do a good job. I believe it's been improved in 2022.
