Weird issue after latest patch
11 replies to this topic
#1 Wes Harr
Wes Harr
  • 29 posts
Posted 11 October 2021 - 03:06 PM
Hello all,
Just curious if anyone has had weird dimension issues, I was checking over a plan and all of the 5 1/2", 3 1/2" etc. dimensions were showing up as 5", 3", you would edit the dimension and it was correct, but on the screen and printed it was getting rid of the 1/2", we closed and reopened the plan and it seemed to fix it.
#2 Joseph Smith
  • 853 posts
Posted 12 October 2021 - 10:33 AM
I've had this many times in the past, it has happened on earlier releases so not related to this patch...however the issue MUST be fixed. If i get structure in the wrong spot because of software issues.....i'll be screwed.
  • Wes Harr likes this
#3 Wes Harr
Wes Harr
  • 29 posts
Posted 12 October 2021 - 05:02 PM
Hi Joseph,
We updated form 2018 (non +) to 2022+ and this was a new issue I haven't run into before, Thanks for the heads up!
#4 James mahan
James mahan
  • 3 posts
Posted 14 October 2021 - 09:38 AM
Has anyone noticed when you move a dimension that it may or may not stay on the extension line?
#5 Brent Hyndman
Brent Hyndman
  • 1,675 posts
Posted 14 October 2021 - 10:49 AM
Under Options, is Show Fractions 'On' (highlighted), or 'Off'  on the ribbon bar when this occurs?
The Show Fractions option will behave in the manner described and will only stay active for the current session. Once SoftPlan is closed and started again, the option will automatically be enabled to show the fractions again.
  • Warren Ducote and John Jones like this
#6 Martin Wrobel
Martin Wrobel
  • 83 posts
Posted 22 November 2021 - 10:17 AM
James
I am experiencing the same issue a lot. I just sent in a support ticket.
Martin Wrobel
Superior Home Design
Michigan
Softplan 2024
#7 Martin Wrobel
Martin Wrobel
  • 83 posts
Posted 24 November 2021 - 10:22 AM
Anybody else having problems with the dimensions moving from the extension lines. Happened today again.
Martin Wrobel
Michigan
Softplan 2024
#8 Rick Kingsbury
Rick Kingsbury
  • 171 posts
  • LocationSpearfish, SD
Posted 24 November 2021 - 12:01 PM
Yes. I have had that happen also.
#9 Philip Frank
  • 577 posts
Posted 24 November 2021 - 02:22 PM
So have I. The dimension line stops short of the extension line, but the dimension value is still correct. I have to delete the dimension and place a new one.
#10 Jim Johnson
Jim Johnson
  • 289 posts
Posted 24 November 2021 - 02:52 PM
Yes,  still happening.
#11 Richard Rubinski
  • 693 posts
Posted 24 November 2021 - 02:56 PM
I had the same problem when editing the dimension I did a clean up and it corrected it.
#12 Bruce Swarbrick
Bruce Swarbrick
  • 7 posts
  • LocationSaskatchewan
Posted 29 December 2021 - 08:15 AM
Yes I have this problem all the time but just redimension. Pain in t
he butt
Bruce's CAD Service
caryl@sasktel.net
(306)296-7777
