Any idea why the gable ends are doing this?
2A7A2F78-F6A1-4945-885E-1A1CDD762624.jpeg 43.85KB
1 downloads
Posted 25 October 2021 - 06:59 PM
1 downloads
Posted 25 October 2021 - 10:46 PM
Posted 26 October 2021 - 07:32 AM
If you select fit to roof it references any roof under the wall segment. There are a few options. First, in 2022 we have the ability to adjust the top of wall in any configuration we want. So, go into the wall edit window, click on top of wall, look for the height that is set to the lower roof (highest point) and work backward off that. You can delete step segments in the case where it jumps up and then adjust the wall heights as needed to fit the sloped top to the underside of the lower roof.
Second, you can pull back the wall so it is only under the lower roof, not the upper. That may cause some gaps you can fill in with the other end of the wall at the taller roof or do some adjustments with another wall segment if needed. Third- if you are using the gable end provided by roof feature, you are going to want to turn the lower one off and use one of the above methods to fit the wall to the lower roof.
Another option I've used in the past if the wall is just technically siding on the gable end truss, is a siding and sheathing only wall definition with the sloped top set where I need it and set at the correct offset to sit on top of the framed wall below and outside the gable truss. Unchecking clean up and sometimes checking anchor helps, but not as much as one would hope they would (sometimes you need to keep adjusting offsets if SP decides it's smarter and that wall ought to reference the floor system below it).
Posted 26 October 2021 - 07:24 PM
Thanks Mark
Using 2020 so I’ll look at the other options,
I like the siding/sheathing idea.
