Window Transparency in Model View
8 replies to this topic
#1 Katia Cline
Katia Cline
  • 20 posts
Posted 13 November 2021 - 03:44 PM
Hi,
Is there a way to modify the windows in the 3D Textured model view so that they do not show any of the interior?
Thanks!
Katia
#2 Richard Rubinski
  • 698 posts
Posted 13 November 2021 - 08:45 PM
Here's one way. Edit the Surface of the Glass(Glazing). Change it to the settings of my screenshot. You'll have to repeat edit all of the windows that are not the same. I think it was Keith Almond that had a post on this.
  • rick hoge and Katia Cline like this
Posted 13 November 2021 - 09:16 PM
I'd change it to 100% opaque.
If you go to the material editor and choose OPENINGS and glazing, you can change ALL the glazing opacity in one operation.
  • David Zawadzki and Katia Cline like this
#4 Ben Ginther
Ben Ginther
  • 141 posts
  • LocationSaskatchewan
Posted 15 November 2021 - 06:20 AM
Also increase the reflectivity!
  • Katia Cline likes this
#5 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 10:41 AM
Thank you everyone!
Keith, where do I find the material editor? I am unfamiliar with this form of editing in Softplan, but it sounds very useful!
Posted 20 November 2021 - 11:09 AM
Katia,
There's almost zero chance you have your toolbars set up the same as I have - I refuse to use the HORRID ribbon bar - so you may have to hunt a little ...
In the 3D window the MATERIAL EDITOR is a multicoloured square (or at least it is in 2020 - We've been so busy we haven't had chance to load 2022 this year) ... You should also be able to select it from the menu bar ... OPTIONS > MATERIAL
Attached File  2021.11.20_11h56m30s_001_.png   74.88KB   0 downloads
if you click it then SELECT openings - don't go any further down the directory - and click on the glazing texture
Attached File  2021.11.20_11h59m05s_003_.png   163.11KB   1 downloads
Then change to the Lighting tab and change the opacity to 100%
Attached File  2021.11.20_11h59m57s_004_.png   109.73KB   0 downloads
It will then change ALL the glazing in ALL the openings to the selected settings.
If you want to change settings on a specific opening independently, you can go down the directory and choose the specific window this way too.
#7 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 11:30 AM
Keith,
Thank you, I found the editor both ways you explained.
I have come up with another hiccup however. My Exterior Finish Textures does not display the Glass option like yours does. So now I am wondering why I don't have all the materials....
Posted 20 November 2021 - 12:12 PM
You're probably using a white texture to depict clear glass. There probably is a texture there ... try changing it to be sure - either way you can change the opening texture to anything you want in that box. As far as I'm aware there isn't a standard glass texture in Softplan. Over the years I've made a few different textures to represent glass.. I use either a dark navy blue or a custom sky texture in my windows these days.
I contend that a window on a normal day with no room lights generally shows almost black ... certainly not clear.
#9 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 02:39 PM
Ah yes, that is what was there. Good to know you created that glass texture and I wasn't missing something! I will play around with that now as well.
Thank you for all the help! I greatly appreciate it.
