Roof Edges on Single Sloped Roofs
11 replies to this topic
#1 Katia Cline
Katia Cline
  • 20 posts
Posted 13 November 2021 - 04:19 PM
Hi,
Just curious if anyone knows how to get the soffit to display on both ends of a single sloped roof? I've been editing the 'taller' end roof plane to be an intersect to achieve this, however that end in model view does not show any soffit.
Is there another way to achieve a single slope/pitched roof design? If so, does the same concept apply when trying to draft butterfly roofs in model view?
Thanks!
  • Grant Krull likes this
#2 Sam Morgan
  • 937 posts
Posted 13 November 2021 - 04:44 PM
Gable on the upper side.  Probably need to set the soffit to raked as well
#3 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 10:30 AM
Hi Sam,
Thank you! That worked beautifully. Another question, how do I get the soffit & finished gable wall end to appear here? The current settings of this roof end is a gable, and the soffit/fascia style is plumb, with soffit depth as 5.5".
Please see attached picture for reference.
Thanks!
#4 Katia Cline
Katia Cline
  • 20 posts
DELETED
  • 5,301 posts
Posted 20 November 2021 - 11:16 AM
We can't get to your C: drive Katia.
Use the MORE REPLY OPTIONS to add pictures.
#6 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 11:20 AM
Hi Keith,
Thank you for the info. I edited my above comment and attached my picture in the way you mentioned. Now, is there a way to delete my C:drive comment?
  • 5,301 posts
Posted 20 November 2021 - 11:25 AM
Just edit it to DELETED. You can't actually remove it.
  • 5,301 posts
Posted 20 November 2021 - 11:28 AM
it looks like it's an intersect, it has to be a gable to show SOFFIT and FASCIA. I've also found in the past that Softplan sometimes doesn't like to change intersect to gable, and have had to change INTERSECT > HIP > GABLE before it understands what I want.
#9 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 11:36 AM
I tried reversing the edit back to hip, and then gable again, but unfortunately it is still drawing this gable end the same way
#10 Keith Almond
  • 5,301 posts
Posted 20 November 2021 - 12:17 PM
Your roof edge isn't referencing a wall ... you MUST have a bearing wall or a beam for it to reference. Generally using beams and changing them to hidden and unchecking EXTRACT IN MODEL is the accepred method. Draw a suitable beam and drag the roof edge "lollipop" to the beam and adjust as necessary.
#11 Katia Cline
Katia Cline
  • 20 posts
Posted 20 November 2021 - 03:00 PM
That makes perfect sense. Thank you for solving my mystery!
#12 Joseph Smith
  • 853 posts
Posted 22 November 2021 - 09:09 AM
This house i was able to associate all the gables to actual walls rather then hidden walls.  The hidden wall height will be important for gable height so watch that also.
