3D Texture
#1 Gerald Horst
Gerald Horst
  • 6 posts
Posted 17 November 2021 - 03:26 PM
I am having trouble with what's happening here...
I changed the material of the stone wall in the materials options tab and the stone portion of the wall is now transparent. the rest of the wall is defined and showing as solid material. Any help or suggestions would be appreciated. Thank you
#2 Joseph Smith
  • 853 posts
Posted 17 November 2021 - 03:29 PM
Do a surface edit and check the opacity.
#3 Joseph Smith
  • 853 posts
Posted 17 November 2021 - 03:32 PM
also looks like you may have an opportunity to create a custom wall with the top 12" or so be siding vs stone....the transition should then be behind your belt board.
also turn OFF cleanup on your porch slab so you can pull it flush or beyond the foundation wall.
#4 Gerald Horst
Gerald Horst
  • 6 posts
Posted 18 November 2021 - 07:27 AM
That did the trick! Thank you
