3D Mode Options Default Settings
#1 Mike Adams
Mike Adams
  • 278 posts
Posted 24 December 2021 - 06:39 AM
After the model has taken shape and you view it for the first time  there are various settings that are "pre-set" and which doesn't look bad...ok.  My problems and time arise when I start messing with it and can't "find my way home".  Good song title.
Is there a way to return to the the "pre-set" or default settings?  I guess I could go thru and write down what I start with.
I have looked in previous posts and questions and can't find an answer.
Thanks and Merry Christmas
Mike
Posted 24 December 2021 - 07:00 AM
That depends on what you have done and how you did it.
If all you've done, is edit it within the drawing - which I think is probably the case - in the 3D window go to FILE > RENDER OPTIONS > LOAD - Open the DEFAULT folder and Select the 3D.mro file. That should reset everything back to your (Softplan's) default configuration.
If you've actually edited the 3D.mro file without saving a backup, then you have more issues.
Merry Christmas to you too.
  • Stephan Page likes this
#3 Mike Adams
Mike Adams
  • 278 posts
Posted 25 December 2021 - 08:03 AM
Thanks Keith
