thicker lines when zoomed in using 2022 vs. 2020
#1 STEPHEN AMSTEIN
STEPHEN AMSTEIN
  • 9 posts
  • LocationFort Wayne, IN
Posted 28 December 2021 - 08:17 AM
I just recently upgraded to 2022. (i am a fairly new user only using SP for a year, long time  AUTOCAD user) I have noticed on 22 that if you zoom in the lines seem to be thicker than in 20. I was wondering if its just the way it is or if there is some kind of line weight adjustment that could be made? Thanks for helping the old AUTOCAD newbie SOFTPLAN user out :)
#2 Gary McKeon
  • 642 posts
Posted 28 December 2021 - 10:56 AM
While in a project press F9. On the lower left of the dialogue box there are several check boxes. Make sure the "display print pen style" isn't checked. All lines should then appear as the same width. If you are still seeing thicker lines then I can only say that the line thickness has been edited to something other than what your default is
  • STEPHEN AMSTEIN likes this
#3 Jon Davis
Jon Davis
  • 543 posts
Posted 28 December 2021 - 03:28 PM
^ If that's not the case, then it could be your screen resolution. I ran into an issue with a new PC, and the resolution was set way to high for 2020 and above SP
#4 STEPHEN AMSTEIN
STEPHEN AMSTEIN
  • 9 posts
Posted 29 December 2021 - 07:22 AM
Gary that work, thanks for the assist :) !!!
