Two questions please.
1) Is there a way to adjust the text line spacing in SoftPlan? Things just seem a bit to far apart.
2) Is there a way to get exterior window & door labels a bit closer to the object they are connected to?
Thank you,
Posted 31 August 2015 - 10:11 AM
Line spacing cannot be changed as such, but depending on what font that you use, you may be able to change it to a similar font that has a slightly smaller line spacing. Let me know what font you use and I'll see what options I can come up with.
Although the default position is set, you can always move the note to suit (as Yvon stated). Use F12 to unlock it.
Posted 01 September 2015 - 01:43 PM
(1) I think line spacing for text should be something the SP experts would be able to add. I think we've all been in situations were you've got 20 notes (Exaggeration!) in a small area on a plan and space becomes a premium. Just my thought!
(2) I was hoping that there would be a default setting for the distance the text label sits away from an object. I don't really want to have to go around to every door and window and move the text individually just because I have a preference.
I thank you guys for your help though!
Posted 01 September 2015 - 01:46 PM
James, What font are you using?
Posted 01 September 2015 - 02:59 PM
Just as a slightly OFF TOPIC comment - Does anyone use, or can anyone think of a use for the DOUBLE SPACED checkbox. I don't think that I've ever used it in over 20 years of using Softplan.
Posted 16 September 2015 - 02:31 PM
Well, that makes it a little more difficult. Try changing it to "Bradley Hand ITC" that will still give you a handwritten look, but is a finer font, and has a slightly smaller line spacing - If it's too fine, print it in a slightly thicker pen. Personally I use "Corbel" which is tighter still, but a much more Arial like Sans Serif font.
STUPID QUESTION .... You do know you're not tied to SOFTPLANS fonts don't you?
