Flush Fitting Garage Door to Exterior Wall
#1 Kaine Gooding
Kaine Gooding
  • 6 posts
Posted 06 January 2022 - 07:36 PM
Good morning, just started using Softplan and have a few questions.
How can you make a Garage Door Flush with exterior wall, not recessed.
And also is there a way to change ONE wall only to a different texture with out having to create another wall and redraw.
The last for the moment, How do I upload a new texture into Softplan, Is there a step by step guide I can use.
Thanks in advance.
  • 5,298 posts
Posted 06 January 2022 - 08:08 PM
Not sure about the door. Try editing the frame offset. I have to ask, How is the actual door going to work flush? I assume it's NOT an overhead door.
No, every material can only have one texture per drawing. However, it's easy to create a new wall ... EDIT wall > Go to DEFINITION, SAVE AS (a new wall) and change the surface material to any other suitable material. for example SIDING A to SIDING B. At a simple level, no other changes are required.
You can use anything as a texture as long as it is in the Softplan (whatever yours is called)\3D\Textures\Bitmaps directory or a sub-directory contained within that directory.
#3 Peter Nauta
Peter Nauta
  • 27 posts
Posted 02 June 2022 - 11:38 AM
I've also just gone into interior mode and draw a wall covering on the exterior of a wall if there's not profile needed
Peter Nauta
Nauta Home Designs
3D Designer
Softplan Computer
i7-6700K @4.00GHz
32GB DDR4
GTX 980Ti
Lumion Computer
16GB RAM
GEFORCE RTX 3070
#4 Derk Burgers
Derk Burgers
  • 91 posts
  • LocationSioux Center, Iowa
Posted 03 June 2022 - 08:25 AM
I just did that the other day to mock up some herringbone garage doors!
