Roof Question - Add Roof to Bump-Out on Floor Plan
#1 Shane Pittman
Shane Pittman
  • 39 posts
Posted 15 January 2022 - 09:42 PM
Hello All
Do want of you know a simple way to add a section to an existing roof? Like say if you have a home and you need to add a bump out.
I have been using the "Add polygon edges"... It seems to work okay, but I wasn't able to get the lollipop to stick to a "plate" today, It would one stick to the top of the wall. I am not sure if I was missing something.
Shane
Posted 16 January 2022 - 10:27 AM
Add polygon edges is the standard method. You should be able to reference the lollipop to whatever you want, however if there are two items in the same plane, you may have to copy the one you want to another location and change it to hidden and not extract in model. Then reference the lollipop to it to ensure it selects the correct item.
  • Shane Pittman likes this
#3 Shane Pittman
Shane Pittman
  • 39 posts
Posted 16 January 2022 - 09:47 PM
Thanks for the help. I will try that.
Shane
