delta drain wrap ms
#1 Jonathan Barto
Jonathan Barto
  • 146 posts
  • LocationPittsburgh, Pa
Posted 24 January 2022 - 02:04 PM
Does anyone know how to do a texture or have a texture of a delta drain wrap for foundation?
Its a texture that has dimples on it.
#2 David Edlin
David Edlin
  • 45 posts
Posted 24 January 2022 - 03:08 PM
Hi Jonathan,
Do you mean something like this? I have not had time to make it seamless but it is not far off for a quick fix?
As attached
Regards
David Edlin
Attached File  Dimple.jpg   90.71KB   1 downloads
#3 Gary Wicklund
Gary Wicklund
  • 200 posts
  • LocationDuncan BC Canada
Posted 25 January 2022 - 08:28 AM
Why do you need a texture for something that gets buried below grade?
just curious
#4 Jonathan Barto
Jonathan Barto
  • 146 posts
Posted 26 January 2022 - 08:23 AM
David
Perfect.  that will work great.
Gary
during our design/ sales process we use generated elevations until the very end (then convert over to line work)   this is a great way to show elevations on the plan set with the grades.
Also with the new 3d export feature it really helps our field guys visualize the end result as well.
Hoping they finish update it to allow the presentation modes.    (so we don't have to do save the drawings 3 times to do each export)
#5 Gary Wicklund
Gary Wicklund
  • 200 posts
Posted 26 January 2022 - 07:35 PM
David
Gary
Ok Thanks
Can you show me an example? I do the same thing with the elevations only I just draw a 1 1/2” line to show grade and leave the concrete showing.
do you use a paint break to set the area to texture or texture the entire concrete wall?
Posted 27 January 2022 - 06:43 AM
I do something vaguely similar, but I use shade breaks and show the grade as grass.
Attached File  2022.01.27_07h45m10s_002_.png   687.06KB   0 downloads
  • Gary Wicklund likes this
