Unattach Window
#1 Kris Marteinsson
Kris Marteinsson
  • 89 posts
  • LocationSalmon Arm, BC
Posted 01 February 2022 - 12:23 PM
I have a rake window in a wall which behaves properly. The gable wall is generated from roof. When I copy the window to be above the patio door, it attaches itself to the patio door. I do not want this. I see no way to separate the window and door. I have put the windows on a different layer but that does not work. Can someone help with a solution for this.
Posted 01 February 2022 - 12:32 PM
Check - EXCLUDE FROM UNIT OPENINGS - on the Header tab of the EDIT menu.
  • Brent Hyndman and David Zawadzki like this
#3 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 01 February 2022 - 12:40 PM
That worked but I had to do it to both the door and window. Looked everywhere but the header tab. Knew it was there somewhere. Thank you.
