The Bone Yard subsitute: on its way
17 replies to this topic
#1 Harlon Suttle
Harlon Suttle
  • 383 posts
  • LocationOverland Park, Ks
Posted 01 February 2022 - 05:55 PM
IN a day or two the "BoneYard" subsitute will be up and going. Thanks to Mark Petri for his patience and help with getting most of the bugs worked out. I will have detailed instruction that should be forth coming as well. One thing to keep in mind is that to be able to signup for the access, everyone will have to be a member here 1st as I will be checking to make sure no Chief A 's etc try and slip in and borrow YOUR work, ideas etc....
Thiis my way of helping and saying many many thanks to all who have participate on this great forum and have saved me untold hours of frustration ....Thanks again and let's work together to make the Bone Yard subsitute a good tool to exchange ideas etc..
Thanks again
  • Warren Ducote, Michael Landry, Mark Petri and 10 others like this
Harlon G. " Buddy " Suttle
casekc49@gmail.com
CELL: 913-339-6242
#2 Kerrin Hester
Kerrin Hester
  • 5 posts
  • LocationLouisville Kentucky
Posted 02 February 2022 - 05:38 AM
Sounds great
#3 Lane De Muro
Lane De Muro
  • 46 posts
  • LocationNew York
Posted 02 February 2022 - 08:32 AM
Thanks again
I don't think you have to worry much about Chief users looking for ideas....as a Chief user for over 20 years, migrating to  Softplan offers a lot more control and versatility.  There are a few areas where Chief does things better (especially it's "view to cad" command and its 2D CAD section) but all in all I think Softplan is a superior program.
Lane De Muro
Posted 02 February 2022 - 08:52 AM
You can draw absolutely anything in 2D in Softplan, very simply. In what way does Chief do it better? Just asking, not criticizing.
What does View to CAD do that you can't do in Softplan?
Maybe there's some items in Softplan you aren't aware of yet!
  • Lane De Muro likes this
#5 Doug Stephenson
Doug Stephenson
  • 75 posts
Posted 02 February 2022 - 02:43 PM
Good afternoon.
I may have missed something or just unaware.
What is 'Bone Yard'?
Please excuse my ignorance.
Doug.
#6 David Zawadzki
  • 736 posts
Posted 02 February 2022 - 02:57 PM
Have you tried  the copy to softplan clipboard and paste to a new drawing for your "view to CAD" function?
#7 Harlon Suttle
Harlon Suttle
  • 383 posts
Posted 02 February 2022 - 03:18 PM
Darn double darn...Started thinking about how to organize the site and began using the files Mark uploaded....well, not a solution that I would use...with probably a few hundred files that would be uploaded and no way to view what a file looks like, I am back to square one....even though there are no "WILD " Indians near me, If I when actitive with what I thought was a good solution, I dare say this forum would have had my scalp...as they say.." back to the drawing board".....1 step forward and two back today.....I'll keep a looking for a solution...
casekc49@gmail.com
CELL: 913-339-6242
Posted 02 February 2022 - 03:25 PM
Perhaps whoever sends you files to upload can send JPG screenshots of either the 3D or 2D (obviously depending on the symbol), that you can resize and use as the link ... the same way the original "Boneyard" did it.
#9 Lane De Muro
Lane De Muro
  • 46 posts
  • LocationNew York
Posted 02 February 2022 - 06:25 PM
Oh, I am sure there is a lot more I do not know about Softplan than I do know. But I am learning.
So, what the View to Cad does is save what ever type of view you have, either an Elevation, Section, Floorplan to a 2D Cad file.  Very nice feature to create an "inset" for a detail.  You can increase the size of the cad view, say from 1/4 to 1/2=1' for easily annotated details.
Chief has a ton of CAD tools to join, break, make parallel (anything can be made parallel) disconnect line segments, combine line segments, but the best part is you can  make CAD details which can be put into the plan file, or put into the Layout (equiv. of Softplan's Plan Set).
You can add categories to schedules in Chief which will automatically populate. So for a Window schedule, you can have call size, unit size, rough opening, net clear opening, glass area, vent area, net clear opening height, net clear opening width and overall opening area size, all of which are required by most of the municipalities I submit plans to.
But, in Chief you cannot have different wall heights, you have to more or less guess at stepping footings, a slab cannot sit on top of a foundation wall unless that wall is a turned down footing type, so you spend a lot of time with the View To Cad faking what can click click click be done in Softplan.
I certainly have a lot to learn about Softplan, but so far I am going with softplan over chief for overall performance.
Just keep all those suggestions and methods coming so newbies like me can learn.
Lane De Muro
#10 Lane De Muro
Lane De Muro
  • 46 posts
  • LocationNew York
Posted 02 February 2022 - 06:26 PM
No, but I will tomorrow!
Thanks!
Lane De Muro
#11 Keith Almond
Posted 02 February 2022 - 08:30 PM
Good afternoon.
Doug.
The "Boneyard" was a section of the original Softplan "Splash" - SoftPlan Links Advise Support & Help site, where users could post details, symbols, paints etc. for other users to download.
  • Tracy Guest and Sean Tobin like this
#12 Brendan Smythe
Brendan Smythe
  • 87 posts
Posted 03 February 2022 - 09:37 AM
Where do we find "The Boneyard"?
#13 Harlon Suttle
Harlon Suttle
  • 383 posts
Posted 03 February 2022 - 09:42 AM
Brendan:
Softplan cancel it a few yeas ago and my thought is to do it outside of SP.  I am working again on some thoughts that Keith Almond sugested yesterday and I will be updating when and IF it goes live..
casekc49@gmail.com
CELL: 913-339-6242
#14 Sean Tobin
Sean Tobin
  • 48 posts
  • LocationRaleigh North Carolina, USA
Posted 03 February 2022 - 01:18 PM
Lane -
I'm a relative new user in SP+ (a year =/-), and I've found that most anything can be done in SP, it just takes finding where the commands are, and learning how to efficiently use them.
I believe what you're describing as the 'View to Cad' SP already does too - you save the view you want, and then add it to your plan set - and set the scale to what you want it to be; and you crop the view as needed.
As to 2D drawing, you can make things parallel, you can fillet, break, chamfer, offset, array, etc.  There are a few minor things I haven't figured out (and I still find it awkward, but I'm used to AutoCAD drawing) for 2D stuff, but the program is better than I originally thought.  [I have not really found good resources to help with things like this though, which is frustrating.]
and I believe that you can add all of those columns you mention to a window schedule - once you add the schedule, just right-click and edit, then go to the 'schedule properties' tab, and you can add or remove the varius columns you want.  I haven't found an easy (or at least intuitive) way to re-order the columns, but there probably is one.
The best 3 ways to learn some of the other features I have found are: 1) just poke around in the program / trial & error; 2) search the forums and post questions; 3) check the you tube channel.  I do wish that there were more 'tips and tricks' or some of these fundamental things covered either in a training, a video, or a manual - but I guess where would the fun in that be?
Like you, coming from another program and learning a new one can be slow and maybe frustrating (it was/is for me at least) - and the good thing is, I really have found very few things that I cannot accomplish with SP.  Its just not always as intuitive, easy to find, or efficient for me (yet) to do.  But there is usually a way to do what I want/need.
Keep using and posting!
And I'm going to keep my fingers crossed for the Boneyard to come back!  This would be great.
#15 Keith Almond
Posted 03 February 2022 - 02:21 PM
...  I haven't found an easy (or at least intuitive) way to re-order the columns, but there probably is one ...
Yes, it can be done, but it's not intuitive.
When you drop a schedule on the drawing, REMOVE all the FIELDS that are included, and add them back in, in the order that you want to see them. Then CHECK the SAVE AS DEFAULT box at the bottom. It will then always appear with the fields you want in the order you specified them.
  • Sean Tobin likes this
#16 Sean Tobin
Sean Tobin
  • 48 posts
Posted 04 February 2022 - 02:08 PM
Exactly how I've done it.  Except then I realized I had forgotten one.  and then realized it was not intuitive.  And then realized I could make it more similar to the orders through the manufacturers.  lol.
each time....it would be nice to get a drag and move ability to shift the columns.
  • Keith Almond likes this
#17 Keith Almond
Posted 04 February 2022 - 02:57 PM
Wouldn't it!
My peeve is ... I don't like the Column Descriptions, and I DON'T like upper case on my drawings, so I ALWAYS have to rename the columns. If we could keep the contents the same except rename them like the title, that would be ideal.
#18 Brent Hyndman
Brent Hyndman
  • 1,675 posts
Posted 07 February 2022 - 08:54 AM
When a schedule has already been added to  a drawing, you can edit the schedule and drag the columns to be a different order from the edit dialog. That should help for the case where you add a new column but want to move it to a new location.
If you hover over the three dots at the top left of the column you should get a hand symbol that allows you the click and drag the column to its new location.
  • John Jones and Sean Tobin like this
