Pbr panel for Siding and roofing
#1 Larry Hartensteiner
Larry Hartensteiner
  • 40 posts
Posted 13 February 2022 - 09:59 AM
I've designed a PBR panel with a 3d polygon. Saved it in the siding file w/ lap,board and batten. It doesn't display like it should. Any and all suggestions is appreciated.
  • 5,301 posts
Posted 13 February 2022 - 11:04 AM
You need to give more information Larry. What is it designed like? What does it display like, and how did you intend it to display?
#3 Richard Rubinski
  • 693 posts
Posted 13 February 2022 - 12:01 PM
I don't know if it makes a difference. Did you did you make it with lines and then go to your Symbols Library "Profiles/ Siding" and use the One Step to create it?
#4 Larry Hartensteiner
Larry Hartensteiner
  • 40 posts
Posted 13 February 2022 - 06:33 PM
I designed it with 3d polygon. The first time I designed it just as a sheet would look. I save ìt to the profile- siding file. Changed my wall definition to the wall profile I created. It just didn’t look like the original file. After a pause in my work I went back and adjusted the depth of the wall siding to match my creation and that made it look better. Then I went back and ajusted the original from over all measurements of a single sheet to 3 ft. center to center. It seems to create a realistic version of a metallic building wall. Thanks for helping.
#5 David Zawadzki
  • 733 posts
Posted 14 February 2022 - 07:25 PM
Post some pictures so we can see what you have been working on, please.
