Stairs disappear in cross section
14 replies to this topic
#1 Kris Marteinsson
Kris Marteinsson
  • 89 posts
  • LocationSalmon Arm, BC
Posted 11 April 2022 - 02:48 PM
I have a cross section and the stairs show up in the model and annotated views. I created a drawing and the stairs have disappeared. Turned on all visibilities. No luck. Turned on all layers. No luck. If I move my cursor over the stair area, the cursor seems to find hidden lines but I can't select anything (possibly to change the display colour). Stumped.
#2 Martin Livingston
  • 693 posts
Posted 11 April 2022 - 02:51 PM
Do you have a "break" in the stairs? Softplan automatically turns off the "Extract in Model" box when you add a "break". See if it is turned off.
#3 Martin Livingston
  • 693 posts
Posted 11 April 2022 - 02:52 PM
I am assuming these were built using the Stair function and it is not a stair symbol.
#4 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 11 April 2022 - 03:10 PM
Built with stair tool. No break. They show up in the model and annotated views and they show up in the 3D model. Just don't show up when I make a drawing of the section.
#5 Jim Johnson
Jim Johnson
  • 289 posts
Posted 11 April 2022 - 03:26 PM
They will go on the layer "Stairs" when you save as drawing.  Make sure that layer is on.
#6 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 11 April 2022 - 03:49 PM
All layers are turned on. Just checked again to make sure.
#7 Richard Rubinski
  • 611 posts
Posted 11 April 2022 - 04:03 PM
You may have to edit the stairs and click on definition make sure visible in cross section is checked
#8 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 11 April 2022 - 04:18 PM
I've looked at the stair definition and can't find "visible in cross section" anywhere. Where is this option?
#9 Richard Rubinski
  • 611 posts
Posted 11 April 2022 - 04:31 PM
Sorry, I wasn't at the computer. I thought it was like  symbols.
#10 ROBERT BROGAN
ROBERT BROGAN
  • 52 posts
Posted 11 April 2022 - 05:06 PM
would you be willing to share said plan with me?
#11 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 11 April 2022 - 05:17 PM
Too bad it isn't. I've just drawn in some fake stairs using lines for the moment but would still like to solve this.
#12 ROBERT BROGAN
ROBERT BROGAN
  • 52 posts
Posted 11 April 2022 - 05:39 PM
Sometimes when you draw stairs on the wrong floor, then you hit cleanup - they move to the position they want to be in.  are they above/below your structure?
#13 Keith Almond
Posted 11 April 2022 - 06:08 PM
Stupid questions - Just to be sure ... Was the section line actually throught the stairs? ... Was background checked? ... Have either the stairs or the section line moved on the plan?
#14 Kris Marteinsson
Kris Marteinsson
  • 89 posts
Posted 11 April 2022 - 08:21 PM
Gremlins. Stairs are in the right location. The section line is in the right location. Neither stairs or section line have moved. Background was NOT checked. This is my preference for sections. I generated a new section with background checked. Saved a drawing. Stairs show up. Generated another section with background not checked. Saved a drawing. Stairs showed up. So I guess it's like when you have a computer problem - reboot.
  • Jim Johnson, Keith Almond and David Zawadzki like this
#15 Keith Almond
Posted 12 April 2022 - 06:02 AM
Glad you have it fixed.
