Importing pdf
#1
Posted 16 April 2022 - 01:53 PM
Any ideas?
I purchased the review module and can create and export PDFs, but the import PDFs part is grayed out and unavailable.
Posted 17 April 2022 - 07:39 AM
Click on File, System Options, System Options again and click on Program Activation. In the new dialog, click Online Update. Click OK to close open dialogs and answer Yes when prompted to save changes. Exit out of the program and then come back into the program and see if it is available.
#5
Posted 18 April 2022 - 07:18 AM
I import pdf all the time using "convert pdf to shapes" in order to create details from pdf files. I know it works pretty well!
- David Zawadzki and Stephan Page like this
Tommy Davis
HomeOptionsDesign@gmail.com
#7
Posted 18 April 2022 - 07:12 PM
I was having problems with the "move to the back" or move to the front" options with 2020.
But since 2022, I can move an image PDF to the back of the screen or move lines etc. to the front.
This is nice for using a site plan that didn't come as a PDF of Lines.
Altho I believe it works with the vector? PDFs also,
But the "move to front, or move to back plays a nice role, somewhere in this.
#8
Posted 22 April 2022 - 06:56 AM
Thomas if you import a kitchen cabinet layout from someone else how would preform that
Thanks Ron
Are you trying to just import the pdf or import the "shapes" ?
If importing shapes, see this video
SoftPlan version 2020 | New Features | PDF Import as Shapes - YouTube
Tommy Davis
#9
Posted 22 April 2022 - 07:29 AM
This is using Review, do you need plus also?
#10
Posted 22 April 2022 - 07:32 AM
I was told I could use soft plan review to import a pdf into the program, where I could draw over it. I have not been successful.
Any ideas?
Did you get a answer from Softplan on this? Were you able to get it to work?
#11
Posted 29 April 2022 - 07:00 AM
Check with Softplan sales, but I believe you can purchase Review as a stand alone module, without the Plus subscription.
Tommy Davis
#14
Posted 12 May 2025 - 07:11 AM
If it is SHAPES, it will import as shapes. If it's actually an image, almost nothing you can do will turn it into shapes (there are some dedicated programs, but the results will vary). For example a generated PDF is probably a vector image (shapes), if it's a scan it going to be a raster image (pixels).
