Solid Stair railing
#1 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 30 April 2022 - 02:40 PM
Customer wants a solid railing (wall) that follows the bottom of the stringer and is at railing height with a cap. Would need to add a grab rail to meet code. I faked this with beams
#2 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 01 May 2022 - 05:50 AM
Anyone got ideas?
Posted 01 May 2022 - 08:18 AM
Not sure what you are asking? If it's just adding the grabrail, then add a standard railing, and uncheck the relevant components until ONLY the handrail is left.
#4 Jim Johnson
Jim Johnson
  • 289 posts
Posted 01 May 2022 - 08:31 PM
I do this with a second handrail.  Create a profile for the wall cap in the Handrail Library.  Just draw the rail on the stairs, set the height, select the cap as the handrail, adjust the rail position as needed, then just adjust the top to the wall in 3D to fit under it.  For the bottom rake of the wall, I would probably just adjust in 3d also.
#5 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 02 May 2022 - 06:07 AM
OK. Somehow I missed that I could rake the bottom of a wall even when there wasnt a roof to fit it to. Thx
