When using plan sets is there a way to display the annotated version of the interior elevation? I draw out the different faces of the cabinets and want to be show the needed notes to the cabinet builder.
Plan set
Started by
John Penner
, May 10 2022 04:11 PM
1 reply to this topic
Posted 10 May 2022 - 06:03 PM
I believe if you drag the Elevation View into the plan set, it asks MODEL or ANNOTATED at that point. You may even be able to right click and switch between them.
EDIT: I doesn't look like you can switch between then. If you change your mind, just erase one and add the other.
