Floor Joist inside existing walls
#1 Terry Mangnall
Terry Mangnall
  • 10 posts
Posted 19 May 2022 - 11:29 AM
I'm adding floor joist inside a room that already has the foundation, slab, walls and roof. I'm wanting to put in floor joist to raise the floor. Each time I put in the set, it automatically put the set on the edge of the slab where the walls are. I try adjusting the edges, but that doesn't work on all the sides. I tried turning off the snap function, but the joists reset to the edge on cleanup.
There has to be an easy fix for this. Can someone help me?
#2 Derk Burgers
Derk Burgers
  • 91 posts
  • LocationSioux Center, Iowa
Posted 19 May 2022 - 12:52 PM
It needs to be set before drawing the floor system.
When in floor system mode, do the following:
-Floor System Options(in the ribbon)
    - Select "Inside of Innermost Bearing" (second group from the bottom on the right)
    - As implied, it will work best if the component of the wall that you want to snap the floor system to is marked as "bearing" in the wall definition.
  • Terry Mangnall and David Zawadzki like this
#3 Terry Mangnall
Terry Mangnall
  • 10 posts
Posted 20 May 2022 - 10:10 AM
Thank you! It worked perfectly.
