Windows - spliting casements into segments and being able to adjust
#1 Bart Lanni
Bart Lanni
  • 3 posts
Posted 26 May 2022 - 02:27 PM
Hello
I am trying to get casement windows that have 3 sections and adjust the height of the sections verticaly.
The middle units needs to be half the size of the top and bottom. Does anyone know how to ?
see the attachment
Thank you
Posted 26 May 2022 - 03:10 PM
Bart,
You're not being clear on what you want to do ... and the attachment only confuses me further.
Is this a single casement window that you want to divide with glazing bars, or a three/six section casement.
If the former, try the PRAIRIE GRILLES and adjust the size to suit. If the latter, then use a single casement 4 units high and add a transom 2 units high, then add a second transom 4 units high. The transoms can then be subdivided in the drawing library.
Worst case scenario. Make a custom window and add custom grilles to suit.
#3 David Zawadzki
  • 736 posts
Posted 26 May 2022 - 09:32 PM
Have you tried stacking 3 units?
#4 Bart Lanni
Bart Lanni
  • 3 posts
Posted 27 May 2022 - 06:18 AM
Thank you all for your suggestions and comments. Will try each and let you know how it went
#5 Ben Ginther
Ben Ginther
  • 141 posts
  • LocationSaskatchewan
Posted 27 May 2022 - 09:14 AM
Looking at a few ideas!
