Any ideas as to how to draw walls like this cantilever one?
9 replies to this topic
#1 Sean Anderson
Sean Anderson
  • 4 posts
  • LocationWhistler, BC, CANADA
Posted 07 June 2022 - 06:45 PM
Attached File  img_9295.jpg   137.13KB   3 downloads
#2 Mark Petri
  • 1,874 posts
Posted 07 June 2022 - 08:49 PM
To draw the sloped section? I'd come up with a custom trim on the window that matches the wall material and is the exact width/height of the distance between the glazing, side walls, roof, underside of the floor. I think you could possibly do a profile in 3D too, but trim would be the first thing I'd try. Just figure out the profile and save it for use as the trim.
  • Derk Burgers and David Franz like this
#3 Mike Adams
Mike Adams
  • 278 posts
Posted 08 June 2022 - 04:51 AM
going to need steel in that baby...
#4 Fred Dickson
Fred Dickson
  • 279 posts
Posted 08 June 2022 - 06:03 AM
Quick & dirty but just using walls, beams, roof and a window.  No steel.
#5 Mike Adams
Mike Adams
  • 278 posts
Posted 08 June 2022 - 06:29 AM
Excellent job Fred.  I was speaking of the cantilever.
#6 Fred Dickson
Fred Dickson
  • 279 posts
Posted 08 June 2022 - 09:46 AM
It looked like this didn't post the first time.... Again, quick & dirty... Just a few minutes to do all the shapes.
#7 Fred Dickson
Fred Dickson
  • 279 posts
Posted 08 June 2022 - 10:12 AM
And a little more time to get a 3D rendered view.  Really very simple - maybe not to build  :)
  • Allen McDonnell likes this
#8 Sean Anderson
Sean Anderson
  • 4 posts
Posted 09 June 2022 - 12:41 PM
  Great work Fred!
I am hoping you could give me some detailed information as to how you created the sloped planes.
I was able to cobble this together with angled walls and pyramidal frurstum solids top and bottom, but it isn't quite right.
Thanks for your input.
S.Attached File  220608 3D01.jpg   56.18KB   1 downloads
#9 Fred Dickson
Fred Dickson
  • 279 posts
Posted 09 June 2022 - 02:06 PM
Here is what I did... I drew 3 of the ext walls the shape and length I wanted.  The end wall is only a beam (not visible in 3d) as a roof reference.  I set my roof overhang to 0 and the slope to 1/12 and used trace roof.  I edited the roof edges to all gables except the one end which is the hip. I added another beam at the bottom of the wall for roof reference only and added the window wall set back in .  All walls then edited to fit to roof.  I added a transom window to the new wall and adjusted it to size.  I then added a shed roof at a 6/12 pitch to the new lower beam.  Again no overhang and a heal ht of 1". Somewhere along the way I added the floor system and a reference point.  I pasted all the exterior textures and such including the 6/12 roof to get the final textures and colors.  To create a more angled look in to the window I used a cube on each side, angled it and adjusted it to fit.  I didn't add that till I did the rendering and it really didn't make much difference.  Finally stacked it all to create the model and fine tuned some of the stuff.  It only took about 30 mins or so to do.  Hope that makes some sort of sense.  Thanks.
#10 Keith Almond
Posted 09 June 2022 - 03:12 PM
Personally, I'd go with Mark's idea of a custom PROFILE trim to all sides of the window.
