Walls not joining
10 replies to this topic
#1 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 08 July 2022 - 06:33 AM
I have walls that are not joining. All set to the same height. I have tried adjusting the wall join tolerance up and down, and even tried redrawing some of the walls. I've tried extending and fileting walls. some join, some don't.  I have saved and reopened the drawing.  The project started as a "copy project to" if that makes a difference.
Any fixes, or do I need to redraw everything?
Thanks, Dave
#2 Gary Wicklund
Gary Wicklund
  • 162 posts
  • LocationDuncan BC Canada
Posted 08 July 2022 - 07:16 AM
Try Softplan support?
#3 Fred Russell
Fred Russell
  • 626 posts
Posted 08 July 2022 - 09:21 AM
Check the offset maybe,  and check if the exteriors is facing the right directions      ?
#4 Richard Rubinski
  • 611 posts
Posted 08 July 2022 - 10:06 AM
Post a screenshot so we can see whats going on.
Rick
#5 Fred Dickson
Fred Dickson
  • 209 posts
Posted 08 July 2022 - 12:43 PM
Exact same think happened to me.  Somehow my wall join was set to .25".  I reset one wall to 6" and group copied the edit to all the walls and it worked fine.... Hopefully that is all it is.
#6 Fred Russell
Fred Russell
  • 626 posts
Posted 08 July 2022 - 12:46 PM
Sometimes  you can open up Tools and use the "Fillet"  and that will join them
#7 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 11 July 2022 - 05:53 AM
Tried fillet and changing the wall join tollerance up and down before i posted, and again now. no luck.  Here is a screen shot...
#8 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 11 July 2022 - 05:54 AM
let me try that again...
#9 Richard Rubinski
  • 611 posts
Posted 11 July 2022 - 10:19 AM
You shouldn't have to do anything for the walls to join correctly.
#10 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 11 July 2022 - 10:36 AM
Thanks all. Been a long time user, and never had this before.  OK, I duplicated one exterior wall to all the others, and mow the exterior corners join but none of the interior walls clean up where they meet the exterior walls.  I had the wall types, heights, and offsets all the same, but something must have been off.  Tried drawing a new partition, same issue. Duplicated the new wall to match the exterior and it cleaned up. changed it back to partition from 2X4 siding and it stayed cleaned up.  duplicated all the interior walls to match the new one and they all worked!  Not sure what I messed up, but it's mostly ok now.  New walls still do not join correctly, but I can work around that.  If anyone knows what I changed that caused this, please let me know...
Dave
#11 Gary McKeon
  • 562 posts
Posted 11 July 2022 - 01:03 PM
Send the plan to tech support. Let them do the legwork since you've checked what you can.
