Saving a complete plan set in one PDF file
saving export pdf
8 replies to this topic
#1 Cory Eisenhardt
Cory Eisenhardt
  • 11 posts
Posted 21 July 2022 - 01:59 PM
Im not able to use the export pdf option. I click on file, scroll down to review, but everything is greyed out and cant click. Do I need to upgrade to be able to do this? I am able "to print" to pdf , by using print and selecting (microsoft print to pdf)
Is there something I'm missing? Would be nice to just load one file and have the complete set of home prints for customers to see vs sending multiple files in one email.
#2 Jason Bishop
Jason Bishop
  • 306 posts
Posted 21 July 2022 - 02:13 PM
I think you have to be a Softplan + subscriber to use this feature.
#3 Henry Buckner
Henry Buckner
  • 342 posts
If you right click on the plan set name (in the navigation bar) it will give you the option " export PDF"
  • Cory Eisenhardt likes this
#4 David Franz
David Franz
  • 12 posts
  • LocationCleveland,Ohio
Posted 21 July 2022 - 02:18 PM
I use plan set and print it with my M.S. print to  PDF print.I am not a SP+ member,I did buy the Review module which was a waste for me.
David Franz
Wood Tech Builders LLC
member Greater Cleveland HBA
#5 Mike Adams
Mike Adams
  • 278 posts
Posted 22 July 2022 - 03:26 AM
You don't have to have SP+ to convert the plans to a PDF.  I  converted to SP+ in 2018 and prior to that I was able to convert to PDF.
FILE>REVIEW>PORTABLE DOCUMENT FORMAT>BATCH EXPORT> gets you to the attached screen shot.  If that doesn't work... don't know.
#6 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 22 July 2022 - 04:56 AM
I do this too except I use a free pdf printing program because Microsoft Print doesn't offer all the page sizes that I use. The one I use is called Pdf reDirect but there are many such programs out there.
  • David Franz likes this
#7 Cory Eisenhardt
Cory Eisenhardt
  • 11 posts
Posted 22 July 2022 - 05:43 AM
Henry Buckner,
If I right click on the Plan set name in the navigation bar it only gives me export to DWG/DXF..HOWEVER, I can print plan set and then do it how I normally do and select the printer-microsoft print to PDF and it works!
Mike Adams, I didn't purchase the Review part of softplan.
THANK YOU TO EVERYONE!
#8 Gary Wicklund
Gary Wicklund
  • 195 posts
  • LocationDuncan BC Canada
Posted 22 July 2022 - 08:06 AM
Just need to purchase the Review module, I had the same problem when my Plus expired after a upgrade.
Its cheaper than the plus subscription if you don’t need plus.
#9 ROBERT BROGAN
ROBERT BROGAN
  • 52 posts
Posted 25 July 2022 - 04:49 AM
do you have adobe acrobat? you can print to that and make anything a pdf
Also tagged with one or more of these keywords: saving, export pdf
